B4 Stereo choices
Hi all. Can any of you recommend a replacement double din head unit for my 2002 Legacy B4 BE5 ?
Currently installed is a Clarion NX501 which came in it last August from Japan. Fabulous unit. If I could get the touch screen to work. Software updates, calibration, etc ... still no use.
So, what will fit, bearing in mind that the fascia is only about 167mm wide so a normal 2din unit of 178mm will not fit.
Thanks all.
