Mishimoto fan on oem relay switches?!?
Hey guys this is my first post,
1993 WRX v1,
the image says a thousand words, 🙈
I am trying to figure out which wires are the hi and low speed Cooling fan wires and which to connect to the new mishimoto fans as there are 2 to each fan, I am presuming the best set up is one fan on hi and the other on low?
would be great to know what you guys have done on yours, thank you
Normally the one on the drivers side is for coolant and the one on passenger side is for aircon .
I personally only run the drivers side one without any issues on a road car , due to removing the aircon and needing the space on the passenger side in front of the rad for my reversed inlet pipework
Ok, The aircon is out, I see yes I could also do with the space for the fmic pipe work,
which colour wires does that fan use on yours?
is one of them from the fuse box?
thanks
I haven't ever traced the fan wire plugs back , so couldn't tell you if one comes directly from the fuse box .
Its fairly obvious which fan plug goes to which fan on the oe loom due to their location on the lower cross member.
Its raining atm but I can take some better pics tomorrow,  for now here's a couple I have already on my phone .
Let me know if you need anymore ,fella Screenshot_20200606-125416_Gallery.thumb.jpg.266ceebf7b308abd4dddcb64eb83e25f.jpgScreenshot_20200606-125449_Gallery.thumb.jpg.a4cb0bd9a0c59d357228ba00ced1aa91.jpg
Took a few pics that you asked for via pm but its eaiser to post multiple photos on here .
Didn't want to remove my fuse box tbh as it and the wiring is 26 years old and I don't want to disturb it lol . Only heavier gauge white wires I can see in that area go to the alternator ,one in the 3 pin plug and 2 attached to the alternator bolt .
Couldn't see any completely white wires going to the fan either , they're all the same gauge wire and the wires that have white also have light blue or turquoise on them too .
Secondary fan (passenger side) plug wire colour un attached on mine ...
Screenshot_20200607-113430_Gallery.thumb.jpg.89a190e99f9adb513b6d7cc25bdf51a9.jpgScreenshot_20200607-113405_Gallery.thumb.jpg.be8e7a36e356e5a399730d9b64c14ced.jpgScreenshot_20200607-113451_Gallery.thumb.jpg.fefbf7fe06d6b4f71e049de69b8fe5fd.jpg
main fan (drivers side ) plug
Screenshot_20200607-113345_Gallery.thumb.jpg.3fa6b2e97ffdcee080fe9adc307646ad.jpgScreenshot_20200607-113322_Gallery.thumb.jpg.76f717608fcbb478f4e34e9c31b77598.jpg
Hopefully it's clear enough and of some use , let me know if you need any more pics and I'll try to get some between the rain showers
