Cig lighter.
Hi, can Aux cig lighter/radio, be easily wired on all the time, ie no key. 2005. Ta.
You could take a live from interior fusebox and add a fuse and feed that to radio and lighters.
I would add a small push button switch with status light in centre console so you can isolate it and have visual reference when it on ....
As above - a straight forward job and the switch is a good idea so you dont leave something plugged in and drain the battery for the cig lighter.
The Radio should already have a perm 12v supply so you could jumper across from that
