V1 v2 Impreza speedo cable both parta,lower essentian!
In desperate need of a lower speedo cable or any advice on what i can do about not having one,changing to electric etc?
Thank
G
Import car parts stock these new 😉
 if the mechanical speedo cable isn't sending a signal to the clocks /ecu ,it will probably limit boost and revs (limp mode) .
As the ECU needs a speed reading in order to calculate loads
Yes is like some sort of limp mode it limits boost,only revs to 4k has been like this for over a year in my car. Import car parts do not supply these any more and are obsolete
Any one if they could reply or email if they have an old one lying about one from an old gear box etc
Would be highyl appreciated
Regards
