recurculating dump valve blanking plate causes backfire
jude123412
ok so my brother has a subaru impreza wrx sti 2008 hawkeye and he has just fitted a blanking plate on the dump valve recurculator to see if it makes turbo flutter noises but in stead it causes a backfire on de-acceleration? anyone know why this is and have a fix for it?
33 minutes ago, jude123412 said:
nah i think he is planning on it
to me the ecu is getting confused, you are meant to remap it when fitting a dump valve, some guy did a video of him putting dump valve on and it was running rough.
I presume the blanking plate has been put in the turbo inlet pipe?, With the valve's recirculating rubber hose now acting as a vta?.
If that's what you've done then u can't vta with a maf, it has to be speed density tuned.👍🏻
