Hi I have a 2019 Forester eBoxer and I am going to instal a dashcam system (front and separate rear camera) which requires a permanent feed (even when the car is locked) and a switched feed (that only becomes live when the engine is on) Can anyone tell me the best location to make these connections please ?
Thanks, Kevin.
  • 4 weeks later...
Try this info. https://dashcameras.net/dash-cam-subaru-eyesight/ The fuse box is under the steering wheel. Lots of info on YouTube or Google
I had  this https://www.thinkware.com/Products/Dashcam/F800PRO installed by a mobile fitter, supplied and fitted for the cost of the camera on Amazon!! Only took him about 20mins
Front camera fitted behind the rear view mirror, EyeSight works fine.
Jim
I ran a fused line direct from the battery into the cabin (my live also powers the GFB electronic boost controller, wideband and boost gauge)
The switched live I got from the fuse box with a fused jumper
https://www.halfords.com/technology/car-audio/stereo-fittings/autoleads-blade-add-a-fuse-576436.html
Found a switched live using a multi meter. On my SF5 it was fuse 9 I believe.
My 10 inch display also automatically switches to rear view full screen when reversing, I did this by splicing into the reverse bulb signal wire.
Mine has an Amazon supplied plug into the OBD socket to power the camera. Simple, neat and tidy..  👍
