Scooby snigs Posted October 15, 2021 Share Posted October 15, 2021 Can anyone tell me if you can stop rear door seals on a classic impreza from leaking ?. Is there any adjustment on the glass runners (so as to increase pressure onto door seals)?. Thanks in advance Quote Link to comment Share on other sites More sharing options...
Scooby snigs Posted October 16, 2021 Author Share Posted October 16, 2021 Anyone any ideas ? Quote Link to comment Share on other sites More sharing options...
Jay762 Posted October 16, 2021 Share Posted October 16, 2021 Not sure on your model but I saw a fix to a similar problem using rubber tubing that was fed down the inside of the door rubber seal to give it more resistance - can you do that? Quote Link to comment Share on other sites More sharing options...
Jay762 Posted October 16, 2021 Share Posted October 16, 2021 here is a replacement https://www.importcarparts.co.uk/parts-info?id=10622&cat=96&sub=97&sec=142&var=85&dc=0&gen=&searchKey=&searchPart= Quote Link to comment Share on other sites More sharing options...
Scooby snigs Posted October 16, 2021 Author Share Posted October 16, 2021 Thank you ,do you know of any aftermarket ones as I need both sides, thank you for replying 😊 Quote Link to comment Share on other sites More sharing options...
Jay762 Posted October 16, 2021 Share Posted October 16, 2021 I dont know that - I saw a couple of used ones on eBay but I dont know if that is just running the risk of leaks still??? Quote Link to comment Share on other sites More sharing options...
Scooby snigs Posted October 17, 2021 Author Share Posted October 17, 2021 Good point .thanks Quote Link to comment Share on other sites More sharing options...
