bazza Posted March 26, 2013 Posted March 26, 2013 strange one but hey ho as above im looking for the bolt sizes that hold the fog lights in front bumper my car is 1995 anyone ooohhhhh and pics coming very shortly just got to throw bucket of water over it
Gambit Posted March 26, 2013 Posted March 26, 2013 Sorry couldn't tell you the size. Only time I changed a fog was on the 55 plate Blobeye
Davsurfa Posted March 26, 2013 Posted March 26, 2013 The bolt that holds the indicator on too is an M6 thread 1
bazza Posted April 5, 2013 Author Posted April 5, 2013 ok just went out to fit front fog lights on to my car and i am going to remove the inter cooler pipe its not connected up to engine so im going to remove it as its in the way . can anyone tell me if i need to undo the bolt for the indicator and fit the fog light to the indicator if you can see what i mean.. also were i have removed the inter cooler pipe the lower housing were the to bolts go for the front fog is missing its been chopped out to get the inter cooler pipe in ..mmmm night mare just trying to work out how these fogs fit on
bazza Posted April 8, 2013 Author Posted April 8, 2013 ok got passenger side front fog on ..but only one bolt hole to screw to on drivers side as the recces has been cut out for the inter cooler pipe to fit i may have to make a bracket up to get fog housed nicely. another job is to remove the winow tint on front windows cant see nothing at night dangerous and also the rear lights are blacked out they look ugly not sure how to get them back to normal ?
Gambit Posted April 9, 2013 Posted April 9, 2013 I believe they should just pull off same as the windows I would use a bit of petrol or WD40 to remove the glue left over. Or you can get some Sticky stuff remover from like Halfords. Unless they used spray paint thinned down for the back lights then I think It's a case of buying new lights. :( Could be wrong there might be a way like soaking in white spirits but never had to do it myself :D
bazza Posted April 10, 2013 Author Posted April 10, 2013 thanx gambit i will look into it windows should not be to much of a problem but dont want to keep the rear lights blacked out DANGEROUS i will have a look at the rear lights today.. maybe try with some soapy water or sugar soap if that fails maybe white spirit cheers
Jay762 Posted April 10, 2013 Posted April 10, 2013 Think the sugar soap might be a bit much for the plastic, white spirit should work though
bazza Posted April 11, 2013 Author Posted April 11, 2013 rear lights are done back to normal makes big difference all done first one almost peeled of in one go other one took couple of hours but all done
Gambit Posted April 11, 2013 Posted April 11, 2013 Nice so was just the film over the top of the outside then. Will have to sort some updated pictures out soon then ;)
