Power steering fluid leak gc8 2000 turbo
Hi
I have noticed a leak of power steering fluid from around the pump, I can't see anything obvious, banjo bolt is tight, can't see any flow of fluid. Is there a place where it commonly leaks from?
Cheers for any help 🙂
Hi mate
I had a similar problem. There is an O ring between the pump reservoir and the pump itself that can be the usual culprit.
Hope you manage to get it sorted ok.
Cheers David, I'll get onto that 😊
 Parts have arrived, will get to sort this out tomorrow 🙂
All done, if that isn't the cause I guess a new power steering pump is next!
Though I just noticed my rear offside brake caliper leaking, and the fluid stripping the paint off the wheel 😔can't believe it, fix one thing, another springs up!
Great job mate, thanks for the pictures too. You’ve done a good job.
Thats a shame about the brake fluid leak. Is it coming from the brake hose?
Cheers David, Sadly not, appears to be a seal that has gone. Car is going into the body shop tomorrow, its literally round the corner so not an issue, but the brakes will have to wait until I get it back. I've rebuilt motorbike brakes, I can't imagine these being any worse. Just a real nuisance!
