Help finding a Offside front wishbone 2004 wagon
Hi all, struggling to find a offside front wishbone 2004 wagon non turbo (gx,gg). I have tried to fit a bluepoint aluminum as it was what my local motor factor had of file for the car (even though the og is steel)  but is was to big - I think its for the sti. I've called a dealer and they for £400 for one 🤨.  I;m not having much luck with breaks. Do anyone have a company they recommend for parts or has one for sale?
If I can't find it on eurocarparts I usually go for ebay and autodoc
Thanks @huami,Ill check out autodoc, not heard of that one before. I did end up finding the part from https://eastkentsubaru.com/ . Just got to drill out the pinch bolt now 😂
ah the pinch bolt can be a nightmare, I spent many hours on it, eventually had to remove both the lower arm and hub knuckle together and replace it all + new wheel bearig. Good luck!
Text 07397979909.
We have a offside wishbone for sale for a Subaru 2005 WRX wagon. It should be the same part as the 2004 one.
