EML light on
Can anyone help got a 2007 wrx Hawkeye change plugs today took on test drive after EML came on saying p2444 code secondary air pump, malfunction no problem before and can’t work out why this has came on
Does it come back if you reset the code?
Secondary air system is a know weak point tbh its gets humidity in it and rusts. Best bet would be to have ti removed and mapped out (dont listen to anyone telling you to just map it out and leave the bits in place, there are butterflys that need removing to prvent them !Removed! up the airflow)
