Justy 1994 fuel starvation
Our Justy 1.2 4WD 1994 with only 12,000 mile on the clock is now in the process of being started. A per guidance received from this forum, the engine turns, and now the ignition is working. There is no fuel being delivered and have removed the flow and return pipes in the engine compartment to confirm. Does anybody know if this model has a fuel pump inertia switch, and if so where is it located and how to switch it back on? If there is a fuse for the pump and if I need to access the sender unit, can I access it by removing the rear seat. any tips like how to hotwire the pump / sender unit to confirm what is the issue?
Cheers Derek
