ej208 fuel lines leaking under intake manifold
i have a fault with the fuel lines leaking under the manifold on a legacy gtb i just bought. what is the internal and external diameter for the lines so i can order some lines to cut to size myself
I had a similar issue.
You can find replacement hoses on amayama parts with the clips too.
I used 5/16 fuel hose but the outer diameter was just slightly bigger which makes the job way more frustrating.
Hope that's of help.
