Service History (Subaru App) and Washers
I bought a 2023 Outback in October and and loving it.  It was serviced by the dealer when I bought it so it won't need a service until the next service interval.  However I am trying to find out of there is a Subaru app which allows access to service history online.  I have found referece to a couple of apps but am not sure which one is for the UK and if it actually does anything.  Can anyone help?
This morning was the first very cold start.  I had an early ride to Edinburgh airport.  I knew it was going to be cold so I topped up the reservoir with screenwash yesterday.  I used the "good down to -5 degrees" without any dilution.  There was probably 25% weaker solution already still in the reservoir.  Over the trip to the airport the car registered as low as -3 degrees at times but typically the temperature hovered around zero.  And the yet the washers still froze - front and rear.  I would have expected my previous car (2015 CR-V) to have coped and that the Subaru would have been even better.  Is the Subaru prone to freezing washers and is there anything which can be done to improve?
Edited by Navrig
mintor calrifications
Just found this thread......
So I'll give up on that idea.  Presumably service history will be via a series of stamps on the log book.
