tiny red light behind needle in the centre of speedo dial
Any help as to what this is? "tiny red light behind needle in the centre of speedo dial"
I have a 2-litre diesel 2013
The light comes on at around 40 km/h and then goes off as the speed passes that point.
No other warnings or alerts come on
I assume it might be the problem of the needle backlight bleeding out when the needle at a certain position to your viewing angle and for you that is when needle at the 40 position ...
It's possible, but it definitely "comes on" around 40 kph and then goes off above and below that speed.
