2008 WRX GB270 timing belt.
We (at my suggestion) are going to replace the timing belt (although I meant take it to a garage when it is running).
I assume that there are belt tensioners that should be replaced at the same time? Is there anything else that would usually be replaced? EG the water pump?
Is there a special widgett o lock the cams and crank pulleys in place?
Any other advice/recommensatios would be appreciated.
