Front subframe replacement
Good afternoon guys I’m in the process of replacing a corroded subframe and I’ve been told that I need all the parts that attach to it to get it through the mot because of the corrosion. The garage can’t tell me what parts I need I can’t find it anywhere on google and I’ve spoken to a few Subaru dealerships and they haven’t been helpful at all so has anyone been in this situation and can help me find the parts I need to buy so I can get my car back on the road
To be fair I have not heard of such a requirement - how do vintage and classic cars get around it?
If any of the structure components is non load bearing (such as a shield, brackets, etc) then it should be fine - clearly a good clean up to inspect and refit in a better condition.
All other components I would replace such as securing bolts, etc but I don't know how they would check that on an MOT.
However, it is more common sense to not fit any defective or rusty parts back on the car
I'm sure you'll be fine if you just replace the subframe.
