p1 gearbox and diff will it directly fit in uk2000 turbo
If your Turbo 2000 is version 5 or 6 then yes. If it's older then you may also need the rear shafts, depending on diff type on your car.
Its a v5/v6 so will be just direct change?
Yes it can be done my mate did it , don't know what's different between the uk box and p1 tho ? Ratios ?
P1 has the gearbox from a 1999 Legacy GT-B (chassis type BH5B).
1st 2nd 3rd n 4th are shorter gears resulting in quicker acceleration and 5th is longer
What oil do I need for p1 gearbox and rear diff?
Is that for both? Cheers
I would use it for both :) But would still PM Oilman they might have an alternative with Club discount code :)
No worries mate. Always goof to try save some money :D
