Forza 5 Top Gear Test Track
Gambit
I'll pop on and get Petes times and update them both :)
And Pete if you goto free run change track to Test track and car to the 22b, then game options remove all opponents set the amount of laps you want I did 6 at a time. and race it you also get some credits while you do it :D
The biggest one I fail on is after the long straight with the camera that hang's over it 2nd to last corner I'm either too slow or over cook it and get a wheel off the track :)
Got a problem now mate I was racing your ghost that 22b isn't standard has aerodynamic wing on the back of it so it's invalid :( I will leave the last time standing thats on the table and just slot Pete's time on.
list at the top of this post
http://uk.subaruownersclub.com/forums/topic/3529-top-gear-test-track-league-leaderboard-trophies/
I think I can beat that time with the wing on anyway I'm close enough now
Car for the TG test tack can't even have the alloy's changed nothing just as you buy it thats it paint jobs are fine though.
Ok mate sorry that you have to try again but if we keep it all the same completely standard saves anyone getting upset. I'm not sure how bad it made on the corners  but did seem to get around a few better than me :)
It that 2nd corner u keep getting me, your car seems to stop instantly , but the follow through that's were a get u only just though your ghost is constantly on mine putting me off. !Removed! good driver on there you are.. I like it
Cheers must be pretty good yourself been beating my times :D
I like to see the difference in times from Forza 4 too with 5 being a new games engine. I do think they have it spot on the sounds are a lot better of the cars too.
To be fair mate, did a lot of track racing and drove a lot of nice cars and the handling on this one is pretty spot on yeah and the sounds too. The 22b or p1 is a pretty good comparison , even the understeer they get when pushed
I agree I even managed to roll the 22b on one lap on that 1st corner just came over that brow made the rear lift as I was turning which in turn made it go soft and lost it before doing 5 rolls across the grass.
And that was the end of them laps :D
Best i can do is not as good as you guy's your alot faster than me but thought i best put in a time :)
1:25.696
Says DNF as set it too 40 laps and couldn't do them all :D
