Can't find the right oil seals for car been in garage for a week now not a import can u use a clutch from a 2.5 wrx turbo sti in a2004 wrx turbo seals keep leakin guy says u can but starting 2 dought it eny body got info on this gear box oil seal ej 205 model eny help would be sound folks cheers
the clutch from sti would be bigger diameter due to the sti being 6 speed and your 2.5 wrx being a 5 speed (I think) try cross referencing the part numbers of the two models ;-)
There's some gearbox seals on here
http://www.importcarparts.co.uk/parts.asp?cat=96⊂=183&sec=277&var=32&dc=
If you give them a ring when ordering the seal you need and ask them as they'll probably know if the clutch is definitely compatible
