When I dip my clutch to pull up to lights, junction etc. The revs drop right down to nearly 0. Then the car revs back up to normal idling revs. It sits fine on normal idle/tock over. It's only when I dip the clutch when driving. Any ideas?
Have you had your car mapped?
No mate. Would that effect it
cam sensor mate, same on my skyline that or your a tooth out
Wouldn't that of put the engine light on though?
Mine does this when I dip the clutch, I just presumed it's a normal thing to happen. My car is mapped by Prodrive though?
I wouldn't of thought it's normal for the revs to drop to 0 and nearly cut out
I would almost put my life on it being the MAF or an air leak. But can be what Ash said among a few other things. But would say MAF
Unplug the maf while it's running and see if it stalls
And if it stalls that means it's not working?
Isn't that what you want though? Means it is at fault rather than something else yet to be found :P
Right I'll try that then. And see if it stalls :)
Have a look at your throttle body, it could be dirty causing it to stick
yeah or the maf, and as for engine lights on the dash, no not necessarily
No engine light on
Yeah, no light then I would check the throttle body first. Apparently the turbo covers it with oil over time or something
