How low can you go? All the way to the floor?
Hi Guy's,
Just a quick thread, how low have you all got your Subaru's Impreza, Legacy, BRZ anything....
Bellow is a guideline of how to set it out:-
Model? -
Lowered by? -
Lowered with? -
What else did you have to change? -
And a picture :D
Thanks,
Tom
I will start it off:-
Model? - Impreza GD
Lowered by? - 70mm all round
Lowered with? - KW Coilovers V3
What else did you have to change? - What didn't i have to change..... ;)
Haha lower than your grannies t**s
Need some bigger rims fill out the rear arch wheel looks a bit lost in the last pic.
Speed bump avoidance in full effect from now on then
Lol 1" of clearance under the exhaust not much room for error lol
I agree with the wheels but the 225/35R17 i have on now only just clear the arches lol would need thin alloys to keep the clearance lol
Speed bump avoidance is in full affect can go over sleeping policeman but not over the bump type have bottomed the engine out 3 times already and had to replace the sump lol
looks wise spot on but around here that **** could get expensive between the potholes and the speed bumps i can see me needing to replace the sump (plus other bits) ALOT!
I need to get my wagon lower
That is !Removed! low  :lol:
I went 35mm and strut braces front and back
you couldnt drive around with a car that low where i live. As the council have put those horrible speed bumps in. The little !Removed! that are like 3 large lumps in the road. Like the ones below, but they have them in three abreast and a much higher...
1502396.jpg?type=articleLandscape
Where i live is pothole central but i'm not changing it now :D
Like you mate we have many here : ( I'm ok in the foz I could prob take them at 50 and still not ground out, unlike my friends mk2 golf every journey is planned in advance haha
Sent from my SM-T210 using Tapatalk
