subaru parts
Can anyone recommend a good supplier for subaru parts? When I (finally) find one, I'll be doing a full service inc gearbox oil, timing belt, water pump, oil, filters, plugs, leads etc. Where's best to get the bits?
Local motor factors for likes of filters, water pump & timing belt kit from likes of ADL Blueprint. Oils, leads, plugs can be found online probably cheaper & with wider range of quality & performance rating as required. Just buy wisely, especially Timing kits & water pumps as no point throwing original quality pump in bin & bolting on a cheap European monkey metal pattern part.
A lot of large motor factors list on eBay so can be good if not getting trade prices locally or if local motor factors not too helpful.
Cheers for the advice and links.
Are the cam belt tensioners auto adjusting on the impreza?
Cam belt tensioner a are self adjusting but it depends what year you get as to which shape you need.
As above, import car parts are brilliant.
I've just had a look and all the gear for a full service and cambelt is only 350-400. Bargain!
Nice we always welcome pictures and how too guides [emoji6]
Will do.
Need my impreza first :( Getting so impatient!
