Impreza sidelight help
Hi recently got a 2009 impreza wrx and wanted to change the standard yellow side lights for something like LEDs or a white/blue bulb (basically something that matches the xenon dipped beam)
So I got some canbus free and meant to be error free LEDs off eBay they worked great had the look I wanted but after 3 days only done about 30 mile the engine management light came on also the si drive and the cruse was flashing and had restricted power I guessed it was the lights so swapped them back and all good now....
Just wondering if you guys have had the same problem and were/if I get get some proper ones that won't make the ecu **** it's self...
Cheers mate will give them ago and see what happens
Good luck, it's a right crappy job to change those bulbs.
