Slightly erratic idle
Won't make any difference mate if I email it, it's a  .rar file makes the file smaller if you don't have it won't unpack so if you download english winrar from here
http://www.rarlab.com/download.htm
then just let that unpack it to say desktop should be good to go :) it's easy to do small file. Install it should pick up on it's own that it's a rar file click on it then should be a folder with some PDF Doc inside :D
  • Replies 53
  • Views 7.9k
  • I also had this problem. is the MAF sensor. carefully reading it wrong sends incorrect information to the ECU. you could have a rich or lean fuel mixture. in 10 years I have changed maf sensor 7
  • Harryburgundy
    Harryburgundy
    Cool...let us know when they arrive and what you get. No time to look at anything this week...off for a lovely long weekend in Devon tomorrow :-)
  • No not yet anyway I might have a PDF workshop manual for you car and it will be free :D
Cool :D
Just looking here, but if there's a VVT (variable valve timer) then this is usually the cause of a rough idle. If a VVT goes faulty (solenoid deteriorates) then it will not show up on a code reader. However, if you take it off and clean it thoroughly you may find the idle will be smoother. If you leave a rough idle too long and a VVT is the problem then eventually it will destroy your front lambda sensor and this will put the EML on.
