Rick 2014 Posted June 22, 2014 Share Posted June 22, 2014 Can anyone recommend any spark plugs for the forester turbo?I don't no if the plugs where ever changed before my ownership. Quote Link to comment Share on other sites More sharing options...
stants Posted June 22, 2014 Share Posted June 22, 2014 The ngk ones seem to be pretty good, weather the iridium ones are worth the extra money is something I've not looked into Sent from my SM-T210 1 Quote Link to comment Share on other sites More sharing options...
Rick 2014 Posted June 22, 2014 Author Share Posted June 22, 2014 The ngk ones seem to be pretty good, weather the iridium ones are worth the extra money is something I've not looked into Sent from my SM-T210 What sort of money are we looking at for the ngk plugs do they vary Quote Link to comment Share on other sites More sharing options...
stants Posted June 22, 2014 Share Posted June 22, 2014 Vary mate, some of the parts sites list at set between 30-40 bits, going up to 70-80 for the iridium ones, I'm sure you could get them cheaper at a motor factors or if you know someone in the trade Sent from my SM-T210 Quote Link to comment Share on other sites More sharing options...
Mr B Posted June 22, 2014 Share Posted June 22, 2014 Standard NGK R are £2 each NGK iridium are probably around £9 each Standard are good plugs & sometimes less problems plus at the low cost you can replace them more punctual. 1 Quote Link to comment Share on other sites More sharing options...
Rick 2014 Posted June 22, 2014 Author Share Posted June 22, 2014 I thought turbo vechiles had to use iradium plugs for better fuel mixture Quote Link to comment Share on other sites More sharing options...
Mr B Posted June 22, 2014 Share Posted June 22, 2014 No iridium has better longevity in terms of electrode tip. High boost cars can benefit with more durable electrode tip but not a necessity. I use standard NGK R in both my NA foresters & also use them in my gtir as get too many problems running them with occasional misfires/plug breakdowns. Subarus are ok with the iridium plugs though. Up to you really on your cars set-up/use & your budget. 1 Quote Link to comment Share on other sites More sharing options...
