Sti PPP 03 mis fire
Hi guys and girls
I have been browsing this site for a while now but this is my first post :-)
I am looking at buying a 03 blobeye sti PPP with 55k full history very good condition.
BUT the seller has warmed me that it through up a mis fire fault code p0303.
It doesn't actually misfire has only happens twice in 6 months allegedly I have sent it to a jap specialist for full dyno run with diagnostic, also including compression check.
So to summaries is it work buying ?
Many thanks
Carl
Hi and Welcome mate
For a misfire can be a few thing's. But I would risk it might be a dirty spark plug to sensors or a bad coil pack. But with that mileage and PPP and if the price is right I wouldn't worry about it as long as it's the car you want :)
Well got the report back on the car :-(
Body work 9-10
Engine cyclinder 3 has very low compression he's calling quoting to out it right, I shall then have a discussion with the seller !
Welcome to the forum -
the result will put you in a good negotiating position if you really want the car then as you are fixing the cylinder you could do some other upgrades - baffle sump uprated oil pump etc and also address why it failed in the first place then you have peace of mind in a sorted engine
Agreed
