Another quick question probably a simple answer I've just bought a set of sti pink injector when I install them do they click into manifold or do they click in fuel rail any replays would be greatly received
Thought I'd ask as I know bugs share a lot of components with classics compared to blob and newer .
I've got a few pics from when I fitted the 550 nismo side feed injectors in my classic that might have helped .
Just take your time, de pressurise the fuel system before you start and bear in mind if you're fitting bigger cc injectors the car will run rough until you get the fuelling rescaled (remapped)
Thanks for the reply I didn't know they had used older parts on the newage I've got a bigger turbo fuel pump injectors and intercooler so will be getting it remapped once every thing is fitted :-)
Tbo I'm unsure what the similarities are between classic and bug , but I read (somwhere) that there are more of the same components than classic and blob upwards.
Nice shopping list [emoji41]
Good luck with the fitting and mapping [emoji106]
P.s I don't know if you have new injector o rings but , it might be worth getting some just in case [emoji6]
Turbos on with some adjustment to fit I've got a complete seal kit for the injectors saves fitting twice for the sake of o ring so should be 300bhp + fingers crossed
