Does a Turbo Sec Air Combi Valve fit on a N/A?
hi,
as i like to fix my Sec Air Combi Valve / Pressure problem i have with my N/A MY06 Forester i can get my hands on an Combi Valve / Pressure of a Turbo engine.
this Combi Valve is located at the passenger side of the engine; the one with the 5 pins plug.
before i fork out £ i like to know if it will fit?
problem with the N/A is that you cannot flash the ECU to delete the Sec Air function as you can do with the Turbo engine. so no blanking off in my case  :(
many thanks,
bt
