i again need your help,i got a big problem whit cooling system and engine oil is mix together,anu sugestions please i need fix that quickly how its inposible
Hi mate sorry just replied to your PM as I said in the PM I think will be Head gasket
Agree with Gambit - that is the most likely cause, when it is apart you will have to check for any warpage of the head
can my anyone tell how i need markt timing belt
The timing belts will have to come off in order to remove the heads and get to the gaskets, there will be marks on the pulleys which will have to be in a set position when the belt is put back on.
If you want to you could use a dab of white paint to mark belt position in relation to pulley.
No worry's hope it helps :)
if in doubt ,get sniff test,to verify ,think its about 10gbp,one wway to find out ,if head gasket,for sure,but those guys above me,know there stuff :0)
I just pretend I do.... Have you ever seen that Tv programme Faking It. I do the same in bed too -_-
:D hi boys,thanks for everyone help job done and my darling is back on the road. But need sel it and jump on turbo verson
Great news about the Turbo version Haha you will never look back :D
