Clutch swap help south Yorkshire
As above really.. Clutch plate on my gc8 has died a death.. Its an import 93 wagon.
I'm after a reasonably priced mechanic who'll do a good job. Plate has worn out.. I've no idea if the flywheel needs skimming as I've not got the facilities too drop the box.
Any help would be appreciated. No gear use at all so I'll have too tow it wherever is reasonable.
Cheers
Martin & dave at Sheffield subaru service give them a bell
Gearboxes on the import versions are dead heavy compared to the uk ones
As said above SSS spot on place I do over 200 mile round trip to use them but worth it.
