brake upgrade recommendations
Hi guys
Looking to upgrade my brakes on my gc8 98 import sti
Maybe the whole set up, but discs and pads i definitely want to do. Front and back
Looking for a rough cost for it as well.
Was wondering what size front and back are and what pot. They are still standard set up and have not been upgraded.
Wondering what you recommend and what set up you guys have?
Cheers
I know most people go for the new age 4 pot fronts 2 pot rears. What sort of upgrade did you mean Track day or just road use ? :D
Upgrade to decent quality discs and pads like Godspeed £150 max
Godspeed upgrade kit can be had about 250 inc refurb Calipers second hand
6 pot conversion is about 500 quid
Then rear 2 pot upgrade is about 200
Just for everyday road use
U feel the difference with the pads and discs matt? And is that for front and back??
I used Carbon Lorraine pads and I can recommend them. They are bite as a wolf and they don`t need preheat.
They can be used on track and road.
My everyday STI has ferodo DS2000 pads. They are also great compare to the stock ones.
If you don`t want to use your car on a track you can do the newage upgrade as Gambit advised above.
I have heard a few people mention the ferodo pads and how much they rate them
What discs do u use with them?
Black Diamond and ebc are also worth a look
No that's front only then 2 pot conversion for the rear
So if you was to do a basic upgrade about 350
I am using the OEM discs on the STI. Please note that CL pads are a little noisy when you brake softly. They squeak.
On my previous car I used Pagid as well. They were also fine.
I never tried EBC but I`ll give it a try next.
Heard good about black diamond but bad with ebc, dont quote me on that tho
Where would i look for them matt
Martin from Sheffield Subaru Service previously advised me to avoid EBC discs and pads. CAn't recall the exact reason, but its enough of a reason for me to avoid them. I went with Pagid discs and pads, they are pretty good OEM stuff, no complaints. Bite really nicely too. Although, Martin did put some braided lines on for me, so that might have something to do with it. :)
