Alloys from other Subarus on the forester
Im looking at other wheels from the Subaru range and ive come across a set saying 5x100.What is the 200 forester set up like then is it 5x100 also?
Yes mate ! The tyres will be be different tho , a guy I know had a set of forester wheels on his impreza
As matt said really you can. we've had a few members cross their wheels over from models.
I don't mind these tyres on the wheels im looking at are shagged anyway.But do all 5 stud Subaru wheels from the wrx,sti,brz etc fit the forester.
Yeah and vag wheels
From what I can remember they do just the years that counts if they do or don't   :)
Just be careful of offset on rears as some rub on the struts. What size are you thinking of going up to ?
I was thinking of a ET35 set up Adam.Ive seen a set up on a Forester with an ET35 and it looks well
  • 2 months later...
If you have self levelling et 35 won't work the bottom spring cup will just rub the side wall if your Forester does not have S/L you should be ok, I have a 2003 Fozzy none Turbo with self levelling and the greater of sets rub the spring bottom cup.
Paul
