blobeye R.I.P! help with advice.......
Nrodgers91
Hi all my gx blobeye has died it still runs slightly but has terrible noise. Been in garage and have been told need new crankshaft pistons sleeves seals and that I would be cheaper buying a new engine as Labour charges would be expensive. full bottom of engine is in bad shape to be honest but I have been trying to find somewhere that I can buy all nessecary parts to fix but cannot find anywhere that sells pistons or that for my car any help? Or is this a lost cause and best to just buy a new engine ?? HELP PLEASE!!!
Try www.importcarparts.co.uk they have all the necessary bits to rebuild, they also sell short motors. Failing that if it's to expensive you could always get one from a breakers but then you run the risk of the same happening
