Snow foam
So then....I need to pick your collective brains on this one.
I now have my lance and 5l of foam...my question is this - do you dilute the foam when you put it in the bottle, or just put it in neat and adjust the lance to get the consistency you want?
If the answer is dilute when you put it in the bottle, then by what ratio?
Cheers guys [emoji106]
I put it in the bottle neat, my lance just draws it into the water at a pre set feed. I can fill the bottle up and use it 4/5 washes before refilling, a little goes a long way. Just have a mess around and if your getting 3foot of snow then maybe dilute [emoji51]
Thanks mate...it has 5 settings which I'm guessing is the rate it draws it up from the bottle. Think I'll half fill it with neat and have a bit play to see what works [emoji106]
Ooh fancy ! What lance did you purchase ?
Got one off the 'ultimate finish' website [emoji123]
