exhaust help for a novice
ChrisD
I'm not sure if they fit standard. But the centre section should bolt to the downpipe. I don't think it'll matter what size the actual pipe work is. If you have a look on Scooby world it should give you an idea of what parts you'll need. And I'm sure someone with a more extensive knowledge will be along to help.
As long as the flages match at either end you'll be ok, some taper for the flange, so it will be 2.5 at the downpipe join then go to a 3" section. If you've got a 2.5" backbox just get a 2.5" straight through section it will join at the cat peffectly
