2004 transponder
does a 2004 sti impreza have a built in transponder to the key?
im asking as im hoping nit so i can get new locks and keys.
the current locks are difficult to open with the single key i currently have.
otherwise i would just get a more cut
thanking you
Yours shouldn't as it's an import think it only does the central locking and not much else you can buy blanks from ipc which are transponder less
Perfect!!!!! Thank you very much!
Drive fast, Race faster
I've the same style of key as yours plus a steel 2nd key which doesn't have anything to it, I've never tried to start the car with the spare, if you want, I'll try it tonight with the spare
If you wouldn't mind helping to prove a point that would be ace.
Just had the Stirling immobiliser removed today and a shiny new Clifford being installed :-)
Sorry Steve,the car decided to spring a coolant leak last night so didn't get to try out the spare, anyway hers a pic of both of mine,
That's not fun for you!!!!! You get that sorted? Yep the key matches mine I'll get a few more cut now :)
New radiator on way should be here tomorrow so fingers crossed that's all it is
Can confirm both keys work fine mate [emoji3]
