subaru legacy gtb
help any idea,s just got back after max 2 miles its lost most ? of its oil no oil in water seems to be on passenger side cant see any oil near heads ,could it be sump gasket was running sweet at that time cheers any imput would be good
bump
Do you have the plastic undertray on beneath the engine ? If the sump had lost it's oil chances are it will be all over that, another thing is to check the filter's on properly and it hasn't been punctured.
Have a good look under the rear of the engine. You are looking to see if the gearbox is wet with oil and probably the underside of the floor too.
If it is, it's probably the rear crank seal. If the areas above are not wet, look inside the under tray. If that's wet and oily, it can be a few things, sump gasket snd sump plug are less likely than front crank seal.
