Correct classic tyre size
Hi
I have a set of 16 turbo 2000 wheels wig currently have 205/50/16 tyres, is this the correct size as I have also seen some wheels advertised with 205/55/16 which so seem more readily available .
Cheers
Matt
Have a look in the door jamb there should be a sticker just below the metal catch that tells you which size tyres you can use, you may be able to go to a 215 section tyre. Mine says 205 or 215 and 15 or 16" rims Not entirely sure though about the impreza
The car came with 15's so all the info is about 15's unfortunately .... So I just need someone who had 16's as standard on an impreza to tell me what there door sticker says
My old Impreza turbo (the one in my profile pic) had 205/50/16 tyres. These were definitely the standard size on the 1999 model. My father had a 1997 model and that had 15 inch wheels as standard.
