apexi power FC and commander
as above, 3 pin to fit MY99-00
£350 delivered
yeah decided this morning on a change of plan mate !
get body work about as spot on as i can, have some fun this summer in it
then sell!
And would this work on my forester
What pin layout is it mate ?
Did you run this on your waggon Matt? and what year is your waggon.
1999 mate
If yours is a import you need to swap over 2 wires , my mapper knew exactly which ones
My mate did a base map for me , but I wouldn't use it mate for yours you can buy a datalogit and do it yourself but that's ideal for tweeks
Base map costs between 100/300 depending on who you use
This tells you everything from temperatures , knock etc
But can't use it in a bug so it's gotta go
Pin layout is
Pin pin blank pin
Hi Matt has it got the remote with it.I will get a pic of my connections in a bit
The commander ? Yep
I have the Uk version on a W plate
Direct fit then mate
Whats the commander for then if the apexi can be mapped by a mapper?Can you map through commander
You can mate if you can see well !
It shows boost , Max boost on run etc , temperatures , injector duty / flow , knock
Think it can do 0/60 times but not found that
Has loads of screens that shows all kinds
My eye sight is perfect
Lol it's easier to see the graphs on a screen but it can be done
Bump
is it 3 plug?
its developed a issue, the idle wasn't right , I done a master reset and it idles fine on my car ,
Might need a auto spark to double check all the connections inside
275 which is dirt cheap as this issue which should easily be solved
Bump 225 posted inc fees
Bump
Can you post a pic of the plug layout so i can check fitment?
