get body work about as spot on as i can, have some fun this summer in it
then sell!
1999 mate
If yours is a import you need to swap over 2 wires , my mapper knew exactly which ones
My mate did a base map for me , but I wouldn't use it mate for yours you can buy a datalogit and do it yourself but that's ideal for tweeks
Base map costs between 100/300 depending on who you use
This tells you everything from temperatures , knock etc
But can't use it in a bug so it's gotta go
You can mate if you can see well !
It shows boost , Max boost on run etc , temperatures , injector duty / flow , knock
Think it can do 0/60 times but not found that
Has loads of screens that shows all kinds
is it 3 plug?
its developed a issue, the idle wasn't right , I done a master reset and it idles fine on my car ,
Might need a auto spark to double check all the connections inside
275 which is dirt cheap as this issue which should easily be solved
