Rear Diff Plug
beginning to wonder what i've bought!
underneath having a look around noticed the bottom of rear diff had fluid.
Put a spanner on the drain plug and it was not tight at all and doesn't really tighten , gets to a point then slackens.
IF the thread had been stripped is there a simple fix for this?
I'm looking on ebay for new plug but can;t seem to find any , has anyone got any links please?
2005 forester X
thanks
To fix the stripped thread you could have it Helicoiled, though it might be more straight forward to swap out the diff cover.
Have a word with the guys at Foresterspares.co.uk they break Foresters so should be able to sort out what you need.
I would remove the filler first so you know you can get oil back in, then remove drain & once drained inspect plug & threads in drain hole.
you may improve it with new plug but also some pu40 black sealer (everbuild) on the threads & nipped to point before slips then left cure for hour or 2 before filling could make it serviceable as is, you may get plug matched in a decent motorfactors or try ICP or local Subaru as doubt it that expensive :-S
Thread repair is possible but bit of a pain.
have ordered new plug so will drain and have a look at thread once that arrives , many thanks
