Intercooler damaged during wash
So i paid my nephew to wash my car he used my pressure washer
As I opened the Bonnet I noticed this
1AB2D0DB-759B-46FB-BF84-702CAEE041BB_zps
Should I be worried ?
Do I need to replace this ? Can I get away with driving it ?
it looks like just the cooling fins are bent, if air can't flow through the fins, it won't cool the air going into the engine, so could det under hard use
use a tooth pick or similar and lot's of patience and straighten the fins up
Ok I see so I can drive my car just not hard ?
Man I got a long trip tommrow so I will be awake all night fixing this
air goes in through the air filter and is 'inside' the intercooler, the intercooler is a heat sink and is there to reduce the internal temp. the temp is reduced by air flowing through the intercooler fins, if air can't flow through, it can't cool the internal air efficiently
it will be fine to drive 'normal', but don't drive it like you stole it
Ok i spent my friday night with 50 toothpicks 4 hours, it took 4 hours wtf my backs killing and my arm still hurts !
This is how badly it was bent:
4781B3C8-8669-447C-8BD6-30F557BB372E_zps
This is what i did i re opened all the s grooves:
690FA2CC-05D7-4EB6-9212-8A0619BE2519_zps
322F638D-14F1-4863-B608-027ABCFF5473_zps
8EA5519E-9D00-4907-988C-BF7EB3658692_zps
Heres the stats after driving kinda hard after 30 minutes:
89B6DE1F-C471-4296-AA75-8B09C3A63DE7_zps
Had the same thing happen to me after some divvyat the car was sprayed the lance straigyt into the scoop, you can get mesh covers that sit on top of the cooler, that protect it from small rocks leaves and other crap
Looks better took some time then [emoji20] I remember that happening too.
