Td05 water pipes...
Hi folks,
Is there a guide to change the water lines on my td05 scooby.. .a littl3 unsure but competant with a spanner ... any help would be greatlu appriciated.
Sam
  • Replies 56
  • Views 8k
  • Samuel_Kelham
    Samuel_Kelham
  • Samuel_Kelham
    Samuel_Kelham
    Silly questions rick .. can i push the elbows into the water pipes easily enough ..whilst the turbos in situe from the top? And pther than the 3 bolts on the turbo vracket ehat else needs to come off?
  • Rick 2014
    Rick 2014
    Yes you can mate I will get some pics for you in a bit.Im working on the car today
Are you changing the lot or just the feed/return for the turbo ?
Easy to change mate.I changed mine when I did the conversion on my Forester.A couple of brackets and banjo bolts and they come off
Looks like a good kit do you have the link ?
Its an ebay one stants atomicsports 14 is the seller mate.. are they a hard job i mean im competant with a spanner but im new to these engines.. cheers for the replies
No idea ricks your best bet as I've not taken mine apart yet,
I guess if you take the turbo off it will make things easier but I presume it can be done in situ ?
Yes it can be done with turbo in place.
Do you have aftermarket exhaust or still standard downpipe with heatshield attached ?
Aftermarket mate no cat im led to believe there 3 bolts i take off and disconnect the oil fred and airbox aaaembly to pull it to the left.. is that all there is to it? How do i get the elbow back into the feed?
Least you won't have to battle with the oem heatshield, I'll let rick answer that as I've not really had a poke around
Ok cheers you 2 ive only had the car 4 weeks already had one £600 bill cnt afford anymore yet and its sat there on the drive so hoping to get it back on the road asap
Ah gutted mate, if you need anything I'm sure we'll be able to help/point you in right direction,
What was the bill for ?
Get some pictures up of her
First problem guys was the small water pipe between rad and block that had a small hole just after i got her home (100+miles so was quite lucky it went when it did) then it began tunning really rough ... had 2 coil packs new downpipe air filter and tyres at the garage hence the bill.. its bankrupt me after insuring it and these problems hence why im on here trying to find a way to do the rest of the niggles myself ☺
Looks nice mate, [emoji106] I'm sure when the teething issues have been ironed out it will bring big smiles out.
I hope so mate its just had a full rebuild with a few tweeks ... only using it for.a sunday blast and i havnt even had one of those yet
Plenty of time for that, not sure how many members we have in Notts, where roughly abouts are you I used to live in Radcliffe years back
You planning on attending any shows ?
We've a stand at japshow on 5th of July if your interested?
Least you know it's going to be right for summer better than driving it when she's sick
Weres jap show located stants? And a bump on the original question if anybodys reading this? Still abit misguided as to how i go about replacing the pipes :)
