Strange noise when rear wheels use traction
Keep it up fellas yer gifs are making me grin
When my rear shock and top mount died I ended up with a wallowy ar5e and a knocking /heavy ticking noise when that corner lifted (inside corner) it used to sound a bit like the inside wheel spinning for traction
Maybe visually check for oil leaking on the shocks and top mount condition. Then pop the boot and push the suspension down sharply on each side of the bodywork where the boot shuts (cos if you push your rear 1/4 or boot lid you'll probably dent it ) the car should bounce once if the shock is ok more if it's not
Hiya, I did this, but it seems that the problem is on the back... the brushes and the bearings i guess... :P
