Wind noise
Got a horrendous wind noise from the osf, when I press against the wing mirror backing it eases quite a bit, the part the window sits into is split but not too keen to replace this. Any other suggestions? Thanks
It's quite a common thing, just a poor design, there's plenty of diy fixes on YouTube or you could take the door apart and replace the rubber bit but it still won't go away entirely.
The previous owner fitted wind deflectors over the door on mine hasn't made a blind bit of difference
Have seen a fix using some simple tubing from  DIY store; check on You Tube for the videos.
ft
