Rear Wheel Bearings Grease?
Doing the near side rear wheel bearing on my 2007 2.5 Prodrive. Besides the usual lateral link bolt being stuck in the bushes the only problem I have is that the new bearing (Blueprint) comes with a packet of grease. Is this grease supposed to be squeezed into the bearing or is it just to go under the new seals? I seem to remember reading that the latest wheel bearings should not have grease added?
Any doubts I would contact Blueprint on that or the actual bearing maker, should be stamped on bearing. I get NTN mainly & through a local bearing shop The Bearing Shop Exeter, they supply needle roller spec & NTN are pre packed for use. Good quality grease for these bearings is Mobil1 synthetic red .
