Help with strange sound on the rear
Hello, so... I changed the Rear bearings... Changed the brushes... but the sound of the "clan clan clan clan" when i have people or baggage at the back, still there... the noise happens only when rear diff needs to work I guess... because otherwise the car (according to the manual) works as a FF.
Any clues what could be guys? :( also, when i do a downshift and this makes the car go slow (by force), it makes a sound like a clutch when its not working well, not grabbing the shift properly...
All these sounds, are at the back... any clues?
Thanks! :D
(By the way, the gearbox and rear diff are from an sti V3)
Diff bearing?
does that thing exist? :P where is it? inside the rear diff? I changed the bearings from the rear wheels... :D
The prop goes into the diff and there's a bearing to stop it moving. around though I wouldn't of thought it would turn up randomly
