Cold air intake
Hi I've recently bought a 2005 wrx and am thinking of adding a K&N cold air intake system.... is it worth £195.00 or should I just replace the standard filter?
Be grateful for any feedback
Cheers
Keep the standard intake, it's meant to be very efficient. I 'upgraded' to a k&n panel but there's arguments for and against 'performance ' panel filters
Think induction kit is only for big horse power, standard set airbox is quite efficient, go for the cosworth high flow dry panel filter. The oil in the k&n can cause problems to the maf
OK thanks, will do. Cheers
I'm also looking for a cold air intake to use along side a japspeed front mount intercooler (not currently fitted) any advice on which fits without fouling the fmic pipework. Want to have several mods fitted at the same time to save on re-map cost. Currently running 355 bhp.
Cheers
Not even worth it unless your pushing 400bhp like me the standard one is quite good to be fair
