safety - using stick-on satnav and airbags
The Forester manual most specifically says you should not attach objects to the windscreen or put them on the dashboard or they will be dangerous if/when the airbags deploy.
In this case where do people mount their satnavs ?
I've always stuck mine to the windscreen like I guess 90% of people.
I would have thought that anything on the drivers side of the windscreen would have been squashed against the windscreen if the airbag deployed, not catapulted into the cabin.
Am I worrying too much ? !
I used to stick mine on the speedo cluster, always over the revs as I didnt need to see it
I wouldn't over think it, Subaru are just covering there asses so you can't sue them should something happen
James
The windscreen is too far away so I figure if I stick it on the flat area in front of the info display, then if the driver airbag hits it, it won't send it in my direction.
I can still see the display OK.
